- Rochester Hills
- MI
- United States
- 1996 Ford E150
The car: 2012 Fiesta S, Manual Transmission
The story: The original engine had to be pulled/replaced due to a hydro-lock in deep water.
The replacement engine was secured via the VIN, and appeared to be a great match, guaranteed low miles, etc.
Unfortunately, prior to installation it was not noted that it had come from a car with an A/T.
Anddddd... It won't start. Took a long time and just the right person to recognize why there was no signal from the Crank Position Sensor
The motors with the flex plate A/T and the motors with the flywheel/clutch have a different mount attached to the block, to locate the sensor.
The one which holds the "CKP" (sorry, called that in the service manual) for this engine is marked "AUTO".
VERY unfortunately, the original engine is long gone. (Also very unfortunately, this cast part must be installed from the clutch side of the block, not from the outside)
SO, a part number for the Manual Transmission specific MOUNT for the Crankshaft Position Sensor is needed.
Anyone have that information, or can show me where to get it? ((( OR, have one of those suckers available for me to purchase???)))
I have a couple of photos on my phone, will try to attach if I can.....
