Ford Fiesta MK8 Armrest
denosg
Zalau
Romania
Ford Fiesta 2019
Where can i find an OEM or close to OEM armrest for Ford Fiesta MK8 (did not come from factory with armrest).
This forum is primarily focused on the North American version of Fiesta. I have no idea if an armrest for a North American version would easily work for an E.U. Spec version. The armrest kit for the North American version Fiesta is a drill and install affair into the back cup holder of the center console. So, you would give up a cup holder to gain an armrest.
I took my armrest out due to manual and it's shifter location - and my elbow. Went to a local dealer and simply ordered the flat-cup tray upper piece.
Just the bear is taking apart the console to remove the assembly and just unclip the upper clamshell half to press on the one ordered - the Fiesta - like any other import model - is using the same mold and modeling - just the fancy trim and it's little spring loaded pieces and clips designed to make it a functional cupholder and fancy cabinet to hold small tiny things - not much else.
You may find the Arm rest interferes more with back seat and stowage - for it rises up about 0.3M (1-foot) above that center hump - making reaching back or under to reach behind the front seats nearly impossible when driving.
