Clutch
Ncebo
NEWCASTLE
South Africa
Ford fiesta 1.4 ambiente 2016
Hello team
Please assist, my clutch pedal stuck down but doesn't disengage the gear. So the engine wanna respond to selected gear while the clutch pedal is stuck down or loose.
Have anyone encounter this issue
May need to bring it in for service - the clutch pedal uses a return spring to "pull the plunger back" and lift the pedal off the floor.
You'll have to get under the dashboard and locate the pivot point of the clutch pedal. See if that spring popped out of the bracket - it also has a pin on the plunger - if the pin is dislodged - the pedal can "jam" onto the floor.
Check this thread, see if it can help...
https://www.fordfiesta.org/threads/has-anybody-else-had-the-same-issue.9889/post-28190
