Hello team
Please assist, my clutch pedal stuck down but doesn't disengage the gear. So the engine wanna respond to selected gear while the clutch pedal is stuck down or loose.
May need to bring it in for service - the clutch pedal uses a return spring to "pull the plunger back" and lift the pedal off the floor.
You'll have to get under the dashboard and locate the pivot point of the clutch pedal. See if that spring popped out of the bracket - it also has a pin on the plunger - if the pin is dislodged - the pedal can "jam" onto the floor.
