2012 se Stalling at red lights
Take a look around the outlet of the tailpipe.
IT should be dark color - similar to "Kingsford charcoal" but not greasy - if greasy- the oil is getting sucked back into the motor - more than likely from the PCV valve.
Another area to check would be when you find the MAP sensor - mine is located here...
But also check the BREATHER hose, that comes off the valve cover to the Air Filter - it too uses a "sponge" to mop up and hold oil - but the little "cup" it rests in - inside the airbox itself - under the air filter media - also can get plugged.
IF this hose gets plugged, the only way the engine can get rid of any vapors is thru the PCV valve and can force leaks to appear around the valve cover and spark plugs are in a trough inside this cover - which can get oil fouled from the inundation of oil which then generates a near dead short for the spark to follow from the coil - the high voltage arc will follow thru into ground outside to the cylinder head versus firing in the spark plug and cylinder.
Itswiggs
Alvin
2012 ford fiesta se
#22
This is a great thread with tons of info. I am having this issue at the moment. Intermittently. Right after I fuel up and at red lights. Great info to look into @Handy Andy
It's common for Fiestas to stumble after a fill-up. Mine will do it if I don't "breathe" the tank a bit. Instead of just pulling to nozzle out right away, try just letting it sit for about 15 seconds or so after it shuts off. Then take the nozzle out slowly, so that the vapors can come out a bit. I usually push the nozzle in and out a few times just good measure. I do all that and it never stumbles.
Don't top up, either. That makes it happen, too.
Especially with more of the Alcohol blends they add to the fuel.
The Fiesta - unless it's branded (that decal on the vehicle by it's "Stuck on" model branding) - as a Flex-Fuel vehicle - too full of a tank can send itself to the shop because of the fuel blend attempts to destroy the EVAP system by trying to trap vapors that wind up making a mess with how the system processes these newer blends.
They (those that sign the forms each year for the newer emission laws to take effect per states that do this...) are pushing more and more corn-based fuels into our tanks and thanking us for the tax income they provide.
IF you can - as you fill up - fill up with slightly less gallons of fuel (quicker-smaller amount of fuel fill) than to wait for the thing to shut off - doing it that way, or not as often leaving more time between fill-ups to dry out the system - leaves an air pocket to help the car start and keep the EVAP system seeing more vapors than the liquid parts of the blend - it "remembers to" pull fumes into the canister and instead it winds up plugging up it's air-passage lines trying to clear/purge it out.
To Add: (If anyone still reads these...)
  • IF you fill too fast these days - the amount of detergents they use, generates a considerable amount of foam - thru the mixing of the liquid fuel and trapped fumes in the underground tanks to push more reclaimed vapors and fuel into the tanks - generates a considerable amount of foam. So,t if you fill up too fast - the smaller volume of tank to keep it in can push this foam and it's trapped liquid into the canister - that, after it dries out - "cakes" and traps even less vapors and won't pass as much air thru it (Making it harder to start)- at time goes on. Think of it this way - after a summer of overfills or foam trapping in that canister - you'll need to spend close to as much as $200 in a DIY hour spent in your garage trying to swap put canisters that are best left to let the professionals and their set of tools on those fittings.
Just an FYI....
Itswiggs
Alvin
2012 ford fiesta se
#25
I’ll try that. Can’t top off anyway, I’ll spill fuel all over the ground of the gas station. Something with the cap less design I guess. Don’t ask me how I know. lol
Itswiggs
Alvin
2012 ford fiesta se
#26
Just an FYI....
Interesting. I completely wrecked out that fiesta I bought for the engine/transmission swap and when getting to the fuel tank and canister stuff In the back this info makes a lot more sense actually being able to see it physically. Thank you for all the info. You must work on these cars so much to know all this about them. It’s great
As a driver I've seen a lot of service shops dealing with overfill and poor canister designs from earlier years - and even warranty work due to the issues of changing fuel blends to more and more alcohol per volume to petrol - it works like a water-softener - even on newer cars.
Reginakay
Marion
2015 ford fiesta
#28
Thanks for the info as I am having similar issues with my car. Was gunna change out the cannister but it expensive so didn't want to if I dont have to. I'll try all these ideas first and see how it goes. Did you have any engine lights on? Mine does and been trying to slowly diagnose the problem but still coming back to the cannister or possibly the electrical system under the driver seat. Any other thought?
Reginakay
Marion
2015 ford fiesta
#29
Engine codes are as followed: P0420, P1450, P2096. I have already replaced the purge valve. O2 sensors, the sensor on the charcoal cannister, and ran a can of B12 chemtool through the system, and advice would be appreciated.
The "P0420" usually tells us that the exhaust system - the catalytic converter - may be getting plugged up. Can be from many reasons up to and including excessive oil blow-by (getting sucked into the motor) or the PCV valve system and its' hoses need to be inspected cleaned and or replaced.
The P1450 code means you might have a system leak - up to and including a bad tank filler neck seal - making it harder for the system to purge fumes from the tank and self-check the integrity of the fuel tank - it might mean service call to a mechanic that knows the EVAP system and can check the system to test the fuel pump, tank and all the seals to help clear this code.
The P2096 code tells me the catalytic converter is not working right - for either air is leaking into the system - or the media in the catalytic converter is crushed or shot making it appear plugged and unable to detoxify the exhaust. This generates a lot of backpressure to the engine so it may mean the pipe or the exhaust system has a plug or crushed pipe - even in the muffler - causing this code. IT can be the main reason for the engine to act like it's stalling - the muffler is plugged or is compromised. There have been incidents where the user backed up to a parking wheel chock and jammed the muffler into the catalytic converter crushing the media from the backing up. The chock caught and pressed the muffler can into the exhaust pipe and bound up the pipe into the media back at the catalytic converter.
Have you been in any accidents or have anyone had to jack up the back of the vehicle to fix something? It's possible - they may have placed the jack in a bad spot and caused this damage, else some form of a rear-end collision occurred and is affecting the exhaust system and the EVAP canister located under the spare tire well.
Reginakay
Marion
2015 ford fiesta
#31
Thanks for the info a little out of my wheel house so I guess ill have to take it to the shop.
