- Grand Rapids
- MI
- United States
- 2018 Ford Fiesta SE HB
Um... why haven’t I heard of this test mode and how do I access it?
This site introduces you to the button, thru the use of it in an MK7 - although it is not complete, it can show you the various steps to engage the button, then you can push the button a set number of times to arrive to a spot in it's test mode, allowing you to view what the vehicle dash "sees".
Then go Here.. What to Know Before Buying | Ford Fiesta Forum
Some of the menu displays are informational results, like sensors, others are "results" from Sensor input - like Fuel Gage - Fuel Pressure and Fuel Level - so the analog gauges and what they display, to Digital input, as a form of calibration - can be checked.
Also there is a "dual" system (I think - don't quote me) used to determine Throttle Position to actual Throttle location - a dual "sweep" mode that is about 17 presses into this test Menu. Another set of presses past that brings you to a "Temp" screen measured in "C" Centigrade - which matches the Coolant Temp sensor reading - or the "Bargraph" dummy-idiot display of where the needle for the Temp Gauge" and "Are you Warmed Up Enough Yet?" questions that arise while driving.
There's the typical TACH which you can compare the Digital to your Analog and even see kM/Hr and use it to help calibrate the Speedo - then there seems to be a section in it that shows a result of wheel diameter - again don't quote me but there's information that even can show DTC or pending's which if none, would say "NONE".
![Driving [driving] [driving]](/images/smilies/icon_smile_driving.gif)
There is even one I've found that shows a "vacuum" hexadecimal result off of the MAP/MAF combo sensor to show the drop in engine vacuum thru the "A" (Auxiliary monitor - various modules in the system it looks at) and "P" (PCM) ports showing their results - you can play with the menu to find areas of interest for yourself - as far as any changes? No, they won't let you make any changes - but at least you can scroll thru the menu list to find the more important functions and help you in troubleshooting.
