Has anyone else had a problem after leaving doors open while cleaning your Fiesta, that the car will not start until you put charger on it for a bit. Is there a battery saver on the vehicle, and if so what do I need to do to start.
Thanks
How old is your battery? Sounds like it is on the verge of dying; simply can't hold a charge. Does it not start other times? Sometimes it's the easiest stuff we forget. If the battery is good, are the terminals clean? Are the ground cable connections clean at both ends? Start with the obvious easy stuff and move on from there.
