Wipers don't cover the windshield
csigona
Poland
NY
2014 Fiesta SE, 2015 Fiesta SE
I only recently acquired a 2014 Fiesta SE, and noticed that there's a good sized spot (about 3 sq. in) at the lower part of the windshield that is neither wiped by the left wiper nor by the right. It's not important with rain, but it would cause an ice build-up when it's snowing. At first I thought the little right-side wiper was the wrong size, but I measured and it's the correct 15".
Is it considered normal and acceptable?
Yes its normally. I've had mine for over three years and no problem.
24" Front LH Wiper Part# WW-2430
16" Front RH Wiper Part# WW-1613
12" Rear Wiper Part# WW-1204
Corvair
Kind of triangle shaped in the middle bottom. It doesn't block you view. I forget which wiper, but I had a new wiper on the shelf from a past car that was one inch bigger, I put it on and worked great. I think it was the drivers side.
