- Lakeland
- FL
- United States
- 2013 Ford Fiesta SE
Hoping someone might know what is causing this:
2013 Ford Fiesta SE 1.6L Automatic
This has happend now twice now. After the first time, I wrote it off as a glitch. Now that it's happened again I'm thinking something electronic is failing:
Symptom: Insert key into ignition, turn key to start. All dash lights light up like they normally world during the starting process but nothing else happens. Starter doesn't even try, no other noises.. simply nothing else happens, not even any clicking. Radio works along with AC and other systems, just no crank/start.
TEMP FIX: Turn key to off position and remove key from igniton. Pop the hood and disconnect the negative terminal from batttery. Insert key, turn to start position (of course no lights, nothing happens.) Hold key there for 10 seconds. Turn key to OFF position, remove key. Reconnect negative terminal on battery. Insert key, turn to start and car starts like nothing was wrong and runs perfectly.
No codes on engine, battery is newish with good charge. Battery terminal cables/connectors are clean and have perfect contact with battery terminals.
I have to suspect this has something to do with an electronic component somewhere since a "reboot" seems to fix it temporarily, just no clue what it could be.
Does anyone have any idea what this might be? Thanks in advance for any and all help.
