Is there a secret to retaining the wheel center caps? In the 48,000 that we've had our 2011 Fiesta we've lost four center caps. Is this common?
Thanks,
Bob
Just the standard alloy wheels. I was thinking that I just may use some type of glue to help hold them in as I see no reason that they would ever have to be removed. I was curious if other owners are having the same problem.
That's not a bad idea, a couple of drops of JB Weld should make them stick really good. Wheels get really hot so you cant just stick any glue on there.
Thanks for the replies! JB Weld is a standard fixture in my garage so JB Weld it is. On the last one that I lost there was one of the tabs still in the wheel. I wonder if the vibrations caused by Michigan's terrible roads is part of the problem?
Bob
That's a thought, especially as last winter was the worst as far as temperature changes that I can remember. The Fiesta has been a great little car so far, hope I can say the same with 100,000 plus miles on it!
