- Edmonton
- Non-US
- Canada
- 2011 Fiesta AT SEL
Hi
New poster long time lurker.
Just bought a cheap 2011 Fiesta for my daughter to pass her test on and drive for a year or two.
Has the dreaded dps6 AT with much grinding and crunching of gears.
Have run a full relearn using Forscan. From the marbles in a tin can sounds I either have a carrier bearing gone or a bearing on the odd gears shaft or something very bad mechanically in the transmission. Possibly an bad inner CV joint on the drivers side too. Stethoscope from the top hasn't narrowed it down beyond not coming from the clutch side of the transmission and getting under the car while running in drive on jack stands isn't my idea of fun.
Computer reports 12 and 13mm clutch material remaining, no TCM codes, a quick check of the actuators and forks shows no issues, can wind the forks in and they spring back out by themselves, swapping actuators no change. No oil leaks. Cannot see any labels saying the seals were done but it's tight in there so don't take that as gospel. In reverse no juddering or failure to engage. In drive can of marbles accompanied by the odd grinding of gears when it tries to change gear.
So found a second hand transmission, but searching online I only see Focus transmission removal videos and the Fiesta is way more cramped. Just wondering if anyone knows of a Fiesta based video? Or anyone here dropped and replaced the transmission can give me some pointers or gotchas? planning to drop the transmission, evaluate which clutches and forks and throw bearings are best and replace seals as a matter of course.
Thanks in advance
John
Thanks in advance
John
