- North Pole
- AK
- United States
- 2014 Ram 1500 2014 Fiesta SE
2014 Ford Fiesta 1.6 non turbo.
Like the title says it takes a long time to get to 180F. Been monitoring temperature via a bluetooth obd scanner. Takes usually 20-30 minutes driving to get up to 180, it wont get there idling.
I have previously pulled the thermostat and tested it when I first got the car as it overheated on the drive home (was due to a couple pin holes in the lower radiator hose.) And the thermostat opened up at 180F while in a pot of water on the stove.
But the car takes a very long time to heat up to temp. It'll get to about 140f pretty fast but 180 I have to be on the highway for a good 20+ minutes usually. Most of my driving has been this winter and its been from -15f to 20 above.
Are these cars just super cold blooded? Or do I need to replace the thermostat?
On tonight's drive home it was about -15F and it never got up to temp in the 30 minute drive home. I got home, popped the hood and felt the radiator hoses and both were cold, so I would think that means the T-stat didn't open.
Anything else I could look for? Oh and the radiator is about 2/3 blocked off with cardboard.
