- Statesboro
- GA
- United States
- 2011 Fiesta
Hey everybody,
My wife picked up a used 2011 Fiesta SE recently and after driving it around for a month or so with no problems, suddenly the brakes became spongy. They would stop the car, but had to press the pedal almost to the floor. I've bled fluid completely through the system (3 times, though I know that was unnecessary...) and no longer believe it's an issue with air being in the system. My next thought is the master cylinder, but the confusing thing to me is 1) there is NO noticeable fluid loss. Brake res. is always topped off at the max line, no fluid leak noticeable on any brake lines, calipers, etc. the cylinders compress fine, and the caliper slides are not seized. Brake booster is working properly, and hose has no cracks/leaks. Furthermore, when I bled the brakes those 3 times, there seemed to be plenty of pressure being generated by pressing the pedal (fluid would spew out quite far, to put it into simple terms...). So, my thinking is that a failing master cylinder would block, or at least lessen the fluid/pressure to some or all calipers. Am I wrong in thinking that? There are no codes showing up on this car, pads and rear shoes have plenty of thickness left on them. What else could it be?
Thanks in advance.
Thanks in advance.
