- Sherwood Park
- Non-US
- Canada
- 2013 Ford Fiesta Titamium
Car is a 2013 Ford Fiesta Titanium Automatic - North American Version
I have two issues, not sure if they are related
1) no crank, no start. When you turn the key to start you hear relays clicking and sounds and lights like it wants to start but there is no crank. If you try multiple times in a row she will start. Sometimes it’s the second try, sometimes it’s the 5th…sometimes it’s the first try. Not sure how to diagnose. I changed the neutral safety switch but get the same results.
2) there is a parasitic draw issue. Again I’m having issues diagnosing this. if I don’t use the car for 3 or 4 days the car may need a boost. I had two new batteries. Since installing the second new battery I triple charge it to prevent issues. i tested the alternator, it’s good - I’m getting 14.x volts when car is running. I tried pulling fuses to find the voltage impact after waiting 30 mins for the car to got to sleep. No luck in finding and issue.
i put the car on Forscan and I don’t see any codes. Ant help or tips would be appreciated.
