It is good to see someone whom has appreciated, if not honored - the value of maintaining, it's an investment.
But then too, you're maintaining an investment - a good investment keeps it value, a great investment maintains its functionality for its lifetime when maintained.
You mentioned...
To me? Own Electric? No!
(I hope for the days when Scotty can give me that Warp Speed - not "
Just The Batteries Sir -
I can Have Auxiliary Power In a Few Minutes" Moment - when it counts - but until then...I'll settle for a car that starts in the morning)
I know batteries - and no, I'm not about ready to take chances on one Electric car - I remember Nissan Leafs have their batteries integrated into the vehicle and if you're in a flood situation - the packs can get flooded and short out - toasts the car - even if you weren't driving it. The standing water ruins the packs - it gets totaled by most insurances.
Around Chicago, South Bend - Beton Harbor - there are winters that can get very bad, you can be stranded. Especially when it is a snowstorm that got you stuck. (I-196 I-94 US-20 corridor for example)
If you kept gas in the tank, you have a much better chance of surviving until rescue - because you have a means to burn fuel - which runs the engine allows for 12 volt power, enough for light and heat - until you're out of fuel.
Batteries? The same way, if you're stuck trapped or otherwise stranded - you have no way to recharge the vehicle - unless you own hybrid.
Cars run out of gas; Electric cars batteries die - Hybrids too - nothing lasts forever.
The issue of Gas as the best source of heat and light is my choice. At least you don't have to await a recharge. Some Hybrids won't allow you to jump start the car if the battery can't recharge well enough to initialize the system so it can be started.
IF you need to know why I feel the way I do, just buy a rechargeable tool at Harbor Freight - the battery backups and chargers you'll need to buy as spares for the tool add in cost - more than to buy the tool as corded or with a 2-cycle engine or just live with the fact you're corded and gassed. Home Depot, Lowes, even Walmart - none of the battery powered "battery packs" ever seems to save the planet, they make more of a mess in the landfill and many local recyclers don't want them.
Cell Phone - take one with you to shovel the driveway; and see when it -1F outside - that it might be able to call back to the house if the signal is strong enough to hit the tower and relay back - some phones won't even operate - their battery will die and freeze up until it's thawed out.
You may need to tie a rope around you so those still at the house can pull you back in before the wolves find you.
Can't wait for Spring...can't arrive soon enough.
