Ford fiesta Cylinder 2 misfire
David_wb
Luton
Ford Fiesta Zetec 2013
Hi, i have misfire in cylinder 2 (p0302) i have replaced spark plugs and coil ignition pack and got some second hand injectors as well. The car still misfires and the code still shows up. However it only does it when idling. Anyone know what the problem could be?
Thanks.
tabijan
Knoxville
TN
2013 SE hatchback
Check compression?
Sixto
2014 SE 1.6 hatchback 136K miles
Bad seal or cracked or failed spark plug wire is also possible - so check all your hose and wire connections.
By that intake is also a knock sensor - make sure it is connected to the harness that routes to the front side of the intake by the fan.
