Ford Fiesta Autolock disable/enable guide
Autolock (If Equipped)
The autolock feature will lock all the doors when:
  • all doors are closed,
  • the ignition is on,
  • you shift into any gear putting your vehicle in motion, and
  • your vehicle attains a speed greater than 5 mph (7 km/h).
If a door is unlocked, the autolock feature will repeat when:
  • your vehicle slows below 5 mph (7 km/h) and then attains a speed greater than 5 mph (7 km/h).
Autounlock (If Equipped)
If the doors have been autolocked, the doors will autounlock only when:
  • your vehicle has been in motion at a speed greater than 12 mph (20 km/h) for more than two seconds,
  • your vehicle comes to a stop,
  • the ignition is switched off or to accessory,
  • the driver door is opened within 10 minutes of the ignition being switched from on to off or accessory.
Note: If you use the power door lock button to lock the doors before an
autolock event, the doors will not autounlock.
Deactivating and Activating Autolock or Autounlock
Note: When programming the autolock feature, carry out the following
steps within 30 seconds or the procedure needs to be repeated. If the
procedure needs to be repeated, wait 30 seconds between programming
sessions.
  1. Turn the ignition on.
  2. Press the power door lock control three times.
  3. Turn the ignition off.
  4. Press the power door lock control three times.
  5. Turn the ignition on. The module is now in programming mode.
Note: A tnne sounds as acknowledgement that the programming mode
has been entered. The safety belt must be engaged otherwise the
Belt-Minder? chime will take priority over other chimes
