- Poole
- Non-US
- United Kingdom
- ford fiesta 2015
I have replaced my clutch master cylinder on my 2015 fiesta. For me it was much harder then I had first thought, although now I know a bit more about how to go about it. The Haynes manual was not that helpful....I needed more detail.
Anyway the new one is in and I have re-connected the two pipes (top & bottom) to the new master cylinder connectors. The bottom one clicked on nicely and seems secure. The top one also clicked on nicely and is securely on. However this top connector slides a small distance up and down on the plastic tube. I am sure this is probably not right. Somethings wrong!!! I then tried finding out more on line, and some references were made to an O-ring. The Haynes manual does not even mention this.
Anyway I had a quick look around the area were the master cylinder comes into the engine apartment and possibly very luckily I noticed a little rubber O ring. I have no clue whether this is what is missing. I have attached a photo of this O-ring(?). I have also shown a picture of it pushed onto the plastic pipe of the top master cylinder pipe (I have broken off the top pipe from the old master cylinder). Is this what I need? Have I pushed it on correctly?
Sorry about the quality of the photos. The O ring does have a hole through the middle of it.
Any help would be much appreciated.
Thank You.
Thank You.
