Fiesta Gear link cable removal
Witbank
NY
South Africa
Ford fiesta mk VI 1.4i
Hi All Ford Enthusiasts
I have a 2012 ford fiesta 1.4
I want to remove the gear cable links assembly.
But under the dash i just cant seem to get it out, after removing the 2 nuts at the bottom above the exhaust heat shield.
There is NO space to get that bracket/rubber out from underneath the interior hvac system. The bolts are so long and ya i have tried.
Any diagrams or methods would be appreciative.
Thanks in advance
Can you get it from underneath or under the hood?
A
Witbank
NY
South Africa
Can you remove the box?
I tried to remove the bottom part of the hvac box but it has this alu heater core that will not allow the cover to be removed.
I can only see removing these cables by removing the whole dash and hvac so i have some space.
It gets wedge up on the hvac cover because of the studs where the bolts fastened is just that extra height that i do not need.
