- Holstebro
- Non-US
- Denmark
- 2017 Fiesta
I have a 2017 Fiesta 1.0 Ecoboost with manual transmission and with a mileage of 56.000 km. It was bought used in 2021. Recently, my mechanic performed annual service and a timing belt replacement. Shreds of rubber from the belt was found in the drained engine oil as could be expected from this engine design. When the work was done, the car had a whirring or rattling noise which sounds like a card flapping in wheel spokes.
The noise appears when the clutch is fully released with the car in gear. Not with the clutch halfway and not if it is in neutral. While driving, whenever the clutch pedal is even lightly touched (1-2 cm of travel), the noise stops immediately, and returns when the clutch pedal is again fully released. I can hear the noise in all five gears when accelerating and it follows engine RPMs. The noise disappears during left turns and increases during right turns. It is quite loud when the engine is cold and during maybe 10 km of driving it reduces but never disappears completely. If I take the foot of the gas pedal, it reduces significantly.
Immediately, focus was on the release bearing so this and the clutch was replaced, but it turned out it did not solve the issue. The car has been in and out from the mechanic for several weeks now. During this time, he inspected the timing belt installation and replaced the fuel pump, both VVT wheels, oil pump, and (at least twice) the new oil and oil filter. But also, all in vain. The noise persists.
Eventually, while I was driving the car, the engine warning lamp came on and off and on again. It was checked at the mechanic, and it turned out to be P0017 which can relate to misalignment between crankshaft and camshafts. The mechanic had the car for a week, but the lamp has not turned on again. However, he did find a loose connecting rod bearing on the crankshaft. This could possibly explain the symptoms, but I do not know what to believe now. Why would that show up exactly at the timing belt replacement? I am quite skeptical that this loose bearing can produce that kind of sound.
The mystery of this case is very frustrating and that is why I am reaching out here. Has anyone here any experience of something similar?
