- Bielefeld
- Non-US
- Germany
- Fiesta 2008
Hey guys.
I'm new to this forum and I'm from germany. I hope my english is well enough
My girlfriends fiesta's doing bad:
Specs: 07/2008, 8566 ACI 1.3 51KW (69HP)
suddenly the revmeter started to fail from time to time (of course it started to occour when I was driving the car...)
Some days later the MIL started to light up.
I had a look with my OBD and it said crankshaft position sensor failure (P0335 in PCM)
And, additonally, the IC give me 2196 (bad/wrong rev signal)
While reading the motor rev through OBD everything looks good.
Every results from OBD looked quite plausible, only temperature seems to have an offset of +15 degrees celsius. (i don't care atm)
The rev meter from time to time suddenly is starting to work again, mostly for a section or a fraction of it. (like having a lose connection or so)
What I checked:
-Changed crankshaft and camshaft sensors. Checked wiring to PCM with multimeter.
-Checked crank and camshaft sensors with oszilloscope (directly on sensors while they were plugged in and through OBD too)
-Crankshaft has a smooth and pretty sinus curve.
-Camshaft looks plausible as well, but signals more square. (but alternates plausible I would say. No professional on this point indeed)
-The rev gauge is working properly.
-The instrument panel is connected properly.
So from this point on I suppose the PCM to be gone
Maybe it could be the instrument as well?
The car is working like it was nothing btw.
To change the PCM or the instruments panel I need to readjust the immobiliser?! But how?!
I'm equipped with forscan btw.
Thanks in advance
What I checked:
Thanks in advance
