Fiesta 1.4TDCI non start
jaa82
Bath
fiesta
I have just replaced the clutch master cylinder on my 2007 1.4tdci Fiesta. Went to start the vehicle and all it does is turns over and not fires. Have checked fuses and rechecked if i disturbed any wiring. There is no fault codes stored, live data shows the crank sensor seeing the engine is turning over and the fuel pressure reads good when cranking. I have sprayed easy start down the inlet which it fires on but then dies as easy start is used. It sounds like a fuel issue?? Im stumped on what else to look at ??
A lot of people with that engine are seeing trouble with worn fuel injectors. We don't have that engine in the US, so I can't really tell you anything about it.
