I changed the engine oil and filter on my Fist the other day, at 1200kms.
When I took delivering of the vehicle I spoke to the service manager about when the first recommended service was due. He told me that a basic service was due after 1 month or 3000kms. They do not change the engine oil at this service unless requested and the first oil change is due at 12 months or 15000kms. Well there was no way I was going to follow that advice.
To get on with the story I changed the oil and cut open the filter to inspect for contamination.
Here are the images I took and a neat trick to see what is inside the filter.
Filter cut open ready for inspection
A section of the filter paper cut from the element.
Filter paper stretched out, as you will note, its very hard to see anything
Now the trick, place filter paper in a vice and compress, squeeze HARD to force as much oil as you can out of the paper. soak it all up with a rag
Now have a look at the difference.
Close ups
I am very pleased with what I found or did not find more to the point. This is what I would term a normal result with hardy any dirt, metallic or non metallic contaminates .
Close ups
