Hi, i have a 2016 Fiesta SE hatch that has been pretty trouble free. However a few electrical quirks have shown up and I’m trying to figure out where to start.
Here’s a list of what’s been going on.
-a couple weeks ago i noticed the radio/CD cutting out for a second or two at random times.
-sometimes when I’d park it’d say “traction control off” on the radio display even though i never changed the setting and it was still on.
-Normally if i have the radio and turn the car off, then open the door the radio shuts off. Sometimes after i open the door the radio will go off and then on for a second before shutting off for good.
-twice I’ve gone to start and all dash lights go on like normal but no start. Turn the key back and try again and it starts.
No CELs. New battery in December and no corrosion on the terminals. What should i try or check? I did see how to do a a BCM reset and am wondering if that is a good thing to try? The procedure is to remove post positive and negative from the battery and touch the connectors (not terminals) and then remove the fuse for a minute. Put everything back together. Is that correct? Thanks.
