- Wellingborough
- Non-US
- United Kingdom
- Ford Fiesta mk6 (07)
Hi. UK here. So, my fiesta had the DTC Code 9359 which I read up about (ignition switch). I changed this but the same code still comes up. Since yesterday when I replaced it, I took a look this morning and 4 new codes have appeared along with 9359. Codes as follows;
9359
9318
C121
C100
E510 (could be ES10)
I have a video on YouTube should you wish to see the codes for yourself. I will add that the car runs fine, it does however, have issues starting if it has been off overnight or at the end of my work shift. It will start but then very briefly shut down for a second before starting up again. During the process it’s like the door locks and unlocks again when it shuts off and starts up again.
Battery voltage is fine, charged it overnight but the issue persists.
Could anyone give me guidance on the codes provided please, struggling to find a straight answer online anywhere.
video - https://youtube.com/shorts/6weWG_GjQu0?si=jrkCO0QqttiKPbhl
second video - startup issue - https://youtube.com/shorts/chLm3N13KAo?si=S5zWT3Ukw7Ks8CeE
9359
9318
C121
C100
