- Prior Lake
- MN
- United States
- 2012 Ford fiesta se
Hi,
I've been going through the process of fixing my 2012 fiesta se after it overheated earlier this summer. I replaced the head gasket because it was shot, and in the process also replaced the timing belt and a couple of tubes in the coolant system. After getting everything put back together I plugged in an obd2 scanner and turned the engine over to see what codes it came back with. The scanner returned the codes p0017, p0300, and p0304.
I tried swapping spark plugs around and coil wires and the codes stayed the same. I've also run a compression test on each cylinder and it came back like this: (all units are lbs/in^2)
1- 110/124/123/124/124
2- 125/126/126/127/128
3- 116/120/122/120/116
4- 130/129/130/130/131
I am also going to run a cylinder leak down test tonight after work. I am wondering what else I can do to trouble shoot what my problem may be?
