Ford Fiesta Bulb Sizes
It?s very important to replace your Ford Fiesta light bulb with the correct size. Before changing your bulb, please verify the corresponding fuse is not blown. The Ford Fiesta low beam headlamps, high beam headlamps, front turn signals and side marker lamps are located in the lamp assembly and can be replaced individually by removing the lamp assembly as a unit.
2011-2012 Ford Fiesta Bulb Chart
2013 Ford Fiesta Bulb Chart
2014 Ford Fiesta Bulb Chart
